Adjustable Shaft(for measurement)
I am looking for an adjusable shaft to measure the perpendicularity of a hole. The problem is that the hole can varry in diameter by quite a bit(.015).
The same concept is used in a bore mic but I do not need to actually measure the hole.
RE: Adjustable Shaft(for measurement)
