Editting revisions.
Editting revisions.
NX 7.5 with teamcenter 8
I have a part and created a revision .02 of it.
Some time later, I added some more changes to that part and thus created part.03.
Now, however, I actually do not need 2 revisions and would like part.03 to be part.02.
Is there a way to do this?
NX 7.5
Teamcenter 8
RE: Editting revisions.
Open TC and delete .03.
Hopefully the part isn't used in many assemblies because then you can't just delete the .03 revision.
Another way is to rename revision .02 to .04 and revision .03 to .02 in this order in TC, and then delete .04. (so .03=.02)
Same remark as above concerning assemblies.
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit
NX 7.5
Teamcenter 8
If you must, you can export 03 out of TC, delete 02 and 03 (after cleaning up references, of course) and re-import 03 as 02. Or the tricks that MickyV007 listed should also work.
NX3 + TC9
NX3 + TC9
Best regards,
Michaël.
Win 7 64 bit
We already found a way around our problem, but I will definitely use this in the future.
NX 7.5
Teamcenter 8
