Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Keep up the good work - excellent site - i'd been looking for something like this for ages !..."
Geography
lagpump (Aerospace)
9 Jan 12 0:39
Does anyone know what the maximum pressure ratio can be designed for a radial turbine using high molecular weight fluid like Cyclohexan?
Thanks in advance.
Lagpump
turb1 (Mechanical)
3 Mar 12 17:40
There is not an exact pressure ratio that radial inflow turbines are limited to.  Roughly speaking, I would say that 10:1 is near the maximum to maintain good efficiency, but there are also total enthalpy drop limitations that you may run into depending on the working fluid (as well as other limits).
I imagine that you are looking at Cyclohexane for an ORC working fluid due to it's high cycle efficiency.  As far as I know, no one has built a cycle using this fluid and the fluid itself is very volatile and is not available in large quantities.
abo2eyes (Electrical)
22 Mar 12 18:31
really i do not know but in siemens  125 mw 94.2 the ratio is 1:10
Close Box
Join Eng-Tips® Today!
Join Us             Close
