ASME VIII-1, Appendix 13, Vessels of non-circular cross sections
Hello everyone!
Please sorry my English. I've tried to make my questions to sound reasonable with a help of almighty Google translator.
Pressure vessel of rectangular cross section externally reinforced by u-beams. U-Beams form a jacket around an inner vessel. Vessel operates under vacuum -14.7 psi gauge and and the steam jacket has 45 psig. As i understand,vessel has to be calculated with ASME VIII-1 Appendix 13-8. My questions are: should be the inner walls of a vessel be calculated with 45 psig + 14.7 psig and outer surfaces with 45 psig only? Shall i use in fomulas for membrane and bending stresses dimentions of a inner vessel (H and h) or shal i use e.g. (H+2xbeam height) sinse there is a load case, when pressure in a chamber and a jacked is 45 psig?
Thank you!
Thank you!
RE: ASME VIII-1, Appendix 13, Vessels of non-circular cross sections
