Urgent Help - Heat flux received and View Factors
Hi everyone,
I have been given a problem at work where I have been told to evaluate the amount of heat/radiation received by a worker at the bottom of a exchanger. If the exchanger is at a certain temperature then we can evaluate the heat flux emitted by the body using stephen boltzamn law (correct me if I am wrong). From some publications I have managed to get an equation for incident received flux which is I= t x VF x SEP. kW/m2
Where t is the atmospheric transmissivity, VF is the view factor and SEP is the surface emissive power. SEP we can calculate using the boltzman law, t is transmissivty which I think certain values can be assumed but lastly I am having problems calculating the view factor. The typical view factor equation avalilible on wikipedia seems a difficult task if I am to make it an excel version as I would need to evaluate the flux at different distances and locations from the exchanger, furthermore the person could be standing between 2 different bundles emitting heat. Once we evaluate the heat from one bindle, assmuming that the person is standing between the 2, can we just add the flux received by 2 sources? Can someone please advise on the problem?
RE: Urgent Help - Heat flux received and View Factors
http://
Seems to me that the wki artical is pretty clear, particularly: http:
TTFN
Chinese prisoner wins Nobel Peace Prize
I did look at all the links that everyone provided and it was all very useful
Thanks again.
