Internal Pipe corrosion
We are doing maintenance to a 50000bls tank in Meta, Colombia. There is some pipe in the plant´s yard, that we could use. Incidentally, I came across a document on the web mentioning the maximun corrosion rate for pipe according to ASME, but didn´t mention the code. Which code adresses this? Thanks
RE: Internal Pipe corrosion
