oscillating converging flow in Y connector
Can you please outline for me behavior(flow rates /pressure/ of fluid in oscillating converging flow in y connector with possible parallel tubes
Thnx
Thnx
RE: oscillating converging flow in Y connector
If you need to know for sure, or if you need to mix fluid then CFD will be required. If you just need to know the delta P, then just make an allowance.
Adrian
