Split spline macro
Split spline macro
Split spline macro
Hi everybody,
I'm working with CATIA since not a long time, and I'm still a little lost, moreover on CATIA automation...The problem is that I want to split a spline (BottomSpline) using a point (ConnectionPoint(6)), and write it in a macro. Here is my code:
        Dim Split1 As Split
    Dim Supref As Reference
    Set Supref = PtPart.CreateReferenceFromObject(ConnectionPoint(6))
    Set Split1 = PtPart.ShapeFactory.AddNewSplit(Supref, BottomSpline)
        Split1.AddElementToKeep BottomSpline
I'm using this 'guide', but honestly I don't understand it pretty well...
http://catiadoc.free.fr/online/CAAScdBase/CAAScdAutomationHome.htm
I gave as arguments the CuttingElem and the ElemToCut, however, it still gives me an error message, telling me Type Mismatch PtPart.ShapeFactory.AddNewSplit"
What does it mean??
Any help is welcome, thanks in advance,
L3munoz
RE: Split spline macro
I've gone ever to the simplest case, like one line splitted by a point, but it stills gives an error "The method update failed". Actually it fails and the macro works but the splitting operation. Any idea of why does it happen??
Language="VBSCRIPT"
Sub CATMain()
    Dim CATIA As Object
    Dim AuxPartDocument As Object
    Set CATIA = CreateObject("CATIA.Application")
    CATIA.Visible = True
    CATIA.Documents.Add("Part")
    CATIA.Documents.Item(1).Activate
    Set AuxPartDocument = CATIA.ActiveDocument
    Set PtDoc = AuxPartDocument
    Set PtPart = PtDoc.Part
    Set PtHybridFactory = PtPart.HybridShapeFactory
    Set PtHybridBody = PtPart.HybridBodies
    Set myPtHybridBody = PtHybridBody.Add
    myPtHybridBody.Name = "Train Geometry"
    Set Point1 = PtPart.HybridShapeFactory.AddNewPointCoord(0,0,0)
    Set Point2 = PtPart.HybridShapeFactory.AddNewPointCoord(10,0,0)
    Set Point3 = PtPart.HybridShapeFactory.AddNewPointCoord(5,0,0)
    myPtHybridBody.AppendHybridShape Point1
    myPtHybridBody.AppendHybridShape Point2
    myPtHybridBody.AppendHybridShape Point3
    Set Spline = PtPart.HybridShapeFactory.AddNewSpline
        Spline.SetSplineType 0
        Spline.SetClosing 0
        Spline.AddPoint Point1
        Spline.AddPoint Point2
    myPtHybridBody.AppendHybridShape Spline
    PtPart.InWorkObject = Spline
    Set mySplit = PtPart.HybridShapeFactory.AddNewHybridSplit(Point3,Spline,1)
    myPtHybridBody.AppendHybridShape mySplit
    PtPart.Update
End Sub
I update my posts. I already fixed the problem. It was absolutely a stupid task. Actually it has to be first the element to be cut, and then the cutting element, so
However, I couldn't manage to split the spline with two points. There is a method, AddCuttingElem
http://catiadoc.free.fr/online/CAAScdBase/CAAScdAutomationHome.htm, but it is applied to the same spline and not to the resulting from point3 cutting. The idea should be then to make a second split operation to that first result, but the problem is that there is no part. I mean, if the spline is L and the cut is done at x, the two parts in theory are x and L-x, but with that function I only get x and L...
