The same title cannot be used on two different attributes
My company recently upgraded to TC8 and NX 8, along with windows 7. When I export an assembly out of TC and try to open up in native UG I get a list of parts that will not open because "The same title cannot be used on two different attributes". Is there a setting I need to change?
NX8.0.0.25
TC8.3.2.2(20110823.00)
Windows 7 SP1
NX8.0.0.25
Windows 7 SP1
Why do you have to be a nonconformist like everybody else?
- James Thurber
RE: The same title cannot be used on two different attributes
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
I think the wording isn't the best and that is causing your misunderstanding of the problem.
The problem is that two attributes are filled out with the same information. I have attached a screen shot of one of the problem parts. Please note that the part number and part description are the same value (but different attributes).
- James Thurber
John R. Baker, P.E.
Industry Sector
Cypress, CA
Thanks for the clarification. I just wanted to make sure you understood what I thought he problem was. I will have the administrator get in contact with GTAC.
- James Thurber
