Configuration to Suppress Fasteners
Hi all,
I'm stumped on this one. I have an assembly with several different configurations which includes some toolbox fasteners. I'd like to be able to configure the fasteners to suppress and unsuppress based on the configuration I'd like to use, but can't figure out how to do it.
Any tips? Seems like is should be very simple, but I've not been able to figure this one out.
Matt
Matt
Matt Smith
Mechanical Engineer
'04 RHIT Grad
RE: Configuration to Suppress Fasteners
If you need a more automated method you could use an IF statement in a DT or Equation.
Matt Smith
Mechanical Engineer
'04 RHIT Grad
Try using a DT.
Weevoe
Dan
www.eltronresearch.com
Dan's Blog
Matt Smith
Mechanical Engineer
'04 RHIT Grad
1) RMB on the config of interest
2) Select "Advanced Selection" from the menu
3) Select File Type in Category 1
4) Condition "="
5) Value should be set to fastener.
This will select all fasteners in the model.
You can isolate, suppress, delete, etc. from there.
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
