Calling a function only when needed
In a Mathcad program, I noticed that a function is recalculated while it does not need to be. Here is an example:
f(x):= x^2 + 1
g(x,y):= f(x) + y
y:= 0,1 .. 10
[graph of g(x,y) vs. y]
Normally, when y is varied, f(x) should not be recalculated, it should be calculated only for the first value of y. But I noticed that f(x) is calculated for each value of y.
Is there a way to force the program to calculate f(x) only once for all?
Thanks a lot,
JC
RE: Calling a function only when needed
Would you do that by
i=0,1;10
g(f(x),i)=fx+y
I recently did a calculation and this function recalculation proved to be quite a bit of problem (calculations took e.g. 10-15mins, whereas the same calculation done as a Flash program was executed in a minute or two). The way I used to get around this problem was switching to using matrices instead of functions. The speed of calculations was greatly improved...
(Your example would be f[x:=x^2+1 and g[x,y:=f[x +y)
