Plotting from a surveyor coordinates
I have coordinates from a surveyor which I am trying to put in Auto CAD 2000 to calculate perimeter and area.
This is what I have.
Start. N72-20-45W 145.42 feet and N73-27-45W 157.72 feet; thence S04-57-42W 855.99 feet; thence S17-20-45E 45feet; S55-15-53E 127.27 feet and S61-53-45E 143.61feet; thence N06-46-59E 493.84feet; thence N06-09-25W 176.0feet, N10-53-32E 94.59feet, N18-49-04E 104.45feet and N17-06-52E 94.0feet to the beginning.
Now this is as written by the surveyor. And unfortunately there is no sketch of the plot. So I tried to put this in Auto CAD 2000 sketch but couldn't figure out how to.
Any information is greatly appreciated.
RE: Plotting from a surveyor coordinates
You input surveying data like this:
Line From Point: (select point or enter coordinates)
To Point :@145.42>N72d20'45"W
To Point: @157.72>N73d27'45"W
etc...
To use the command "LIST" and see the results in Surveyors units, set your units to "Surveyor".
Hope this helps,
Carl
Thanks Carl.
How would you do this in InRoads?? or MicroStation??
Thank you
here is an example of a traverse I did in microstation, assuming starting at coordinates 20,000,20,000
PLACE LINE
XY=20000,20000
DI=304,N87^28'W
DI=662.94,N87^59'30"W
DI=178.61,N32^45'W
DI=143.88,N3^17'30"W
bonus: you can write this in a text editor then call up the text file from the key in command line. suppose you had a text file called traverse.txt
at the keyin     @d:\traverse.txt
Inroads, you could write the courses in cogo classic. Check out the locate direction command in help.
