NXOpen for CAE (generate JT from op2)
Dear All,
I find the following document:
Simulation Connection
June, 2009
Introduction to NX Open for CAE Processes
I found it on the web but I couldn't download it.
It contains some scripts, too.
I would like to write an exe file to generate JT file from Nastran op2 file.
I wrote a small code but I got the following error message:
Unhandled Exception: System.EntryPointNotFoundException: Unable to find an entry point named 'X81JA_SPP_CreatePostviewForResult' in DLL 'libcaepost'.
at NXOpen.CAE.Post.JA_SPP_CreatePostviewForResult(Int32 viewIndex, Tag result, Boolean overlay, Tag resultParamter, Int32& postviewId)
at NXOpen.CAE.Post.CreatePostviewForResult(Int32 viewIndex, Result result, Boolean overlay, ResultParameters resultParamter)
at op2_jt_disp.NXJournal.Main() in D:\Graph_it\nx_tudasb\VB_net\Projects\op2_jt_disp\op2_jt_disp\op2_jt_disp.vb:line 182
Thank you for your help.
June, 2009
