Plotting to a tiff in Catia V4 ?
Is it possible to plot to a tiff file larger than the screendump size? I Would like something that could be sent out at or near full scale. If this is possible what needs to be done?
RE: Plotting to a tiff in Catia V4 ?
It runs like that :
/ HEADER BLOCK DEFINITION
*BEGIN_HEADER
/ ------------------------------------------- 10 CHARACTERS DEVICE NAME
*NAME TIFF
/ -------------------------------- 45 CHARACTERS PLOTTING PANEL COMMENT
*COM TIFF 200 DPI
*TYP PRINTER
*END_HEADER
/ PARAMETERS BLOCK DEFINITION
*BEGIN_PARAM
/ --------------PLOTTING KEYWORDS (REFER TO CATPUB REFERENCE MANUAL)
*EXPORT TIFF
*RDY 200
*END_PARAM
/ EXECUTION BLOCK DEFINITION
*BEGIN_EXEC
if [ -s $CATOUT ] then
# qprt -P lp0 $CATOUT
cat $CATOUT > $HOME/toprint
else
echo " the file $CATOUT doesn't exist , check your traces"
fi
*END_EXEC
/ RUN-TIME BLOCK DEFINITION
*BEGIN_RTIME
CATOUT=$HOME/catout.tif
export CATOUT
*END_RTIME
The $HOME/toprint is the .tif file in 200 DPI
Stan
get the syntax errors and I do get a execution successful window. Plot cfg file looks as such:
*BEGIN_HEADER
*NAME TIFF
*COM TIFF 300 DPI
*TYP PRINTER
*END_HEADER
*BEGIN_PARAM
*EXPORT TIFF
*RDY 300
*END_PARAM
*BEGIN_EXEC
*END_EXEC
*BEGIN_RTIME
export CATOUT
*END_RTIME
