Hail Dent Repairs ?
Hail Dent Repairs ?
I have some limited hail damage (roughly 20) in 2004 Nissan roof and hood. When the Texas sun is on the damage it is impossible to find ;in cooler temps they return. I have heard stories about using dry ice and alcohol to "pull out" dents. Anyone have a reccommendation ?
RE: Hail Dent Repairs ?
Seriously, I have seen people use a suction cup method with success. I have never heard of dry ice doing it. It might make a good Mythbusters episode to investigate it though.
The other method that works is to push it out with a spoon and a sliding rolling action. It takes practice and you have to have access from underneath. Head linings are a pain to remove, but doable. Double skins are well impossible from a practical point of view.
Another method that requires repainting is a trick with like a mig welder/spot welder that then pulls the rod back like a pop rivet but with a big flat mandrel. Body filler also works for small dents, just paint the roof a different but harmonious colour so there is no mismatch apparent.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Or try the consumer kit that does the same thing; a little bridge jacking mechanism and a hot melt glue gun. Pulls a bit harder than a suction cup can, but it's the same general idea.
Or get out the ball pein and ding it all over.
Mike Halloran
Pembroke Pines, FL, USA
That could be promoted as the golf ball effect aerodynamic fuel saver.
Pat
for site rules
The "paintless dent removal" guy will have a hard time getting a bunch of hail dents out. The one who quoted me on the same dent (as above) explained his process as removing interior trim to gain access to the back side of each dent, then pushing the dent out with a variety of levers, etc., that he carries in his toolbox.
You circle the dent with the heat source, and the thermal expansion drives the dent up. Quench it with the wet rag, and it goes pretty flat.
- test on scrap first.
cheers
Jay
Jay Maechtlen
http://www.laserpubs.com/techcomm
Vacuum pump from the front or spooning from behind are the only methods I know that don't damage paint.
Pat
for site rules
