Slab Placement Above Column Splice
I received a question from the Contractor regarding his slab pour sequence on a 6 story steel building. His subcontractors are concerned about placing concrete above a column splice before the lower floors are in place.
The building has been plumbed, the braced frames are complete, and I cant seem to find an engineering reason not to do it. Also, there are no light gage walls in place.
While I understand this is a "means and methods" question, does this throw up a red flag to anyone else?
RE: Slab Placement Above Column Splice
Particular care needs be taken to failure at the joints forming kinked joint leading to loss of structural geometry.
