Quick Connect Search
Does anyone make a 1/4" female quick-connect that mounts to a printed circuit board in the horizontal position (either thru-hole or surface mount)?
In other words, the "flat" of the terminal would be parallel to the panel.
RE: Quick Connect Search
Suggestion:
Try a surer way to succeed:
http://www.thomasregister.com
under "Product/Service" enter "Quick-connect" and the search will return
Connectors: Quick Connect/Disconnect - 13 Companies
Couplings: Quick Connect/Disconnect - 309 Companies
ETC.
