Good thermal insulation in a tight space
In trying to find a solution on google I stumbled across this forum and think I might have to stick around. I'm a youngster, junior in college and managed to land a part time job as an ME working for a bunch of EE's trying to build a ridiculously complex and quite irrational device that doesn't really have any real world application, but it's a clever idea and has been quite the learning experience so far. But to my question. I figured this to be the best place to ask. I'm trying to find something I can use for insulation that is 1/8" max 1/32" minimum, is somewhat flexible as my diameters range from 1.75" to 2.5", and has a k factor of .05 at the most, .03 ideal. And air isn't much of an option as this will be submerged in water 100'- 300' depth and finding room for sealing will have to change the current design. Thank you for your help whether it be an answer or a point the right direction.
RE: Good thermal insulation in a tight space
Note that based on your description, the insulative properties are likely to be compromised, since there's ample room for water to intrude and directly contact the interior object.
TTFN
Chinese prisoner wins Nobel Peace Prize
My cars go "bdoom vroom pop pop whistle", my music goes "bvvv wub wub bvvv", and my hearing goes " "....
I think he also wants flexibility. Maybe hollow glass spheres in silicon rubber or cast urethane? I think the requirements are impossible.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Pat
for site rules
TTFN
Pat
for site rules
It's interesting that I have presumed he meant solid PS and you have presumed he meant PS foam.
I wonder who is correct and that in no way implies I think it was me. It implies a layman has given insufficient information and we both made assumption as to what he meant vs what he said.
Anyway, either way, glass bead in a thermoset resin could work for him.
Pat
for site rules
