NX7.5 INHERIT CLEARANCE PLANE FROM MCS IN DRILL OP.
Does anyone know of a way to inherit the clearance plane set in the mcs group in a drill operation so that you do not have to specify a clearance plane in every drill op. I know in the milling operations under non-cutting moves/tranfer-rapid tab you can set it to use inherited but in a drill operation you have to set the clearance plane in avoidance and use inherited is not an option. Any ideas would be much appreciated! Thanks.
RE: NX7.5 INHERIT CLEARANCE PLANE FROM MCS IN DRILL OP.
If you have already specified a plane in avoidance in the operation, and you want to go back to inheriting, go to the details panel in the Operation Navigator and turn the inheritance on. Be sure to hit the big green check mark!
Mark Rief
Product Manager
Siemens PLM
But in my personal drilling template, I am not getting it to work, in the inherited from column for the Smart Clearance Plane, it says default value instead of the mcs group, and I am assuming that is the reason that I am not getting it to work. How do I go about editing that?
Thanks.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
