"BEND on element xxx to xxx not properly specified"
I have a model where I entered an element and indicated a bend.  I then went back and inserted a branch element at a previous tee location.  When I go back to the first element and continue the model does not show a bend at the intersection and when the model is run reports the error in the subject line, which continues:
"The following element should define the DOWNSTREAM side of the bend".
How do I recover from this without rebuilding the model?
RE: "BEND on element xxx to xxx not properly specified"
Answered in the Intergraph CAESAR II Forum.
Richard Ay
Intergraph CAS
