Blocking Pilot POTT schemes for GOAB switching
For a 138KV fiber optic POTT scheme on network lines with a POTT instanteous O/C ground setting of about 300 amps, does your utility block the scheme during GOAB (group operated air break switching) on the lines?
thanks JIM
thanks JIM
RE: Blocking Pilot POTT schemes for GOAB switching
The instantaneous elements are set above the pole disagreement level with some more sensitive elements set to trip on a time delay.
