API 6A WAFER CHECK VALVE MANUFACTURERS
4
Team,
Does anyone know an API 6A Wafer Check Valve manufacturer?
Thanks in advance!!
RE: API 6A WAFER CHECK VALVE MANUFACTURERS
There are many suppliers, for instance:
http://www.gestra.com/products/a2_rkiht.php  (Flowserve, but the actual factory gives more detail)
NOTE! Always true for this forum: if you narrow the question you will get a faster and better response.
Allow me also to give on the advice an old and experienced engineer gave me many years ago. This has helped me a lot!
'First you try to find the solution yourself, at least twice. Then you start asking for advice by informing what you have found and where you are stuck!'
Thank you very much Kandeel76 and gerhardl; however I'm looking for API 6A Class 10000 Swing Check Wafer Type.
Please give more data; flow, diameter, fluid and any additional operational requirements.
I am not sure I would have selected this type of checkvalve. Could give operational problems if not selected/dimensioned correct.
... nozzle check valve might be a good choice, ref. gustorfs post above! (other suppliers exiats, Noreva one of the tops.
