NX6 Part Size Scaling off, designed in inch, need metric (not convert)
I have a wireframe part, basically a dummy, that was created in inch, but should have been metric. One would think no big deal, however, it is also the wrong size by a factor of 25.4.
The person who created the part messed up. For example, a bar that should be 8mm in diameter is 8in in diameter, making it 203.2mm in diameter after converting using ug_convert_part.exe. I am using NX6.0.
I tried converting the part to metric, then importing it into a new file and using a scale of 1:25.4, but it gave me an error message that reads 'Cannot scale solids, components, or expressions - ignoring scale'. I also tried importing the inch part into a new metric part and it gave me an error saying the part has to be in metric to be imported.
Any ideas? Thanks in advance!
RE: NX6 Part Size Scaling off, designed in inch, need metric (not convert)
Edit -> Transform...
...and scale the model by a factor of 1/25.4?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
"Good to know you got shoes to wear when you find the floor." - Robert Hunter
John R. Baker, P.E.
Industry Sector
Cypress, CA
