Dimensions - Failure to Open Data Files
when dimensioning I am getting a "failure to open data files"
I have rebooted, replaced component, made a completely new model and drawing.
This is an issue that has just come up.  I have not had the issue in the past.
any ideas? ponder
thanks
RE: Dimensions - Failure to Open Data Files
Hello
Are you using NX7.5.4 or NX7.5.5 and NX75Custom from GTAC support forum?
Bellow is some information about it.
NX7.5.4 added new folders and files to the UGII\drafting_standards folder. I've included these in the latest update of NX75custom (attached). You may experience drafting errors if your NX75custom\CustomerDefaults\drafting_standars folder does not contain the following folders:
ansi
din
eskd
gb
iso
jis
You can also copy these files from the UGII\drafting_standars folder.
MN
NX5, NX6, NX7.5 and NX8
I-deas 12, NX I-deas6.1m1
Solid Works 2009
