Disconnect Switch & Breaker
I am working on a cap bank application in a medium voltage system in Canada. Does the canadaian code ( or a local province code)require a disconnect switch infront of the breaker for maintenace reasons?
RE: Disconnect Switch & Breaker
Utility system or industrial?
Jocelyn VersaVac. It's an industrial type application.
They are not inside MEG type mounted circuit breakers.
Obviously, there would need to be a way to de-energize the breaker for maintenance, and a local disconnect would be convenient.
Also, some safety rules may require a "visible" break to allow maintenance work to be done. But the NEC does not require this.
