Expansion joint thru structural slab connecting pile caps?
Our building is designed to have expansion joint. Part of structural slab is connecting to pile caps. And also, the said slab will become our basement floor. Is it safe that expansion joint will cut thru the slab joining the pile caps which is essentially part of the foundation?
Our design drawing does not provide detail on this expansion joint to show that joint will totally cut thru the slab like in the wall does have.
Please any expert can give his valuable opinion is highly appreciated.
RE: Expansion joint thru structural slab connecting pile caps?
Is your attachment supposed to show what you are talking about? If so, what part of it? You would be better just to give us a specific plan to comment on.
http://www.nceng.com.au/
"A safe structure will be the one whose weakest link is never overloaded by the greatest force to which the structure is subjected" Petroski 1992
