material properties of concrete
Does ETABS has automatic properties for C30, C35, C40 concrete? I am having a hard time filling the material properties dialog box in etabs if I want to change to,ie, C35. Is there any reference that I can look up to in knowing different properties(I've tried to search on the internet but it doesnt relate to ETABS dialog box for properties).
RE: material properties of concrete
No, you will have to define this manually. I have copy pasted the information for you from the ETABS model.
Units are KN,mm
  MATERIAL  "CM20"  M 2.402E-12  W 2.356E-08  TYPE "ISOTROPIC"  E 22.36  U 0.2  A 9.89999989542412E-06
  MATERIAL  "CM20"  DESIGNTYPE "CONCRETE"  FY 0.5  FC 0.02  FYS 0.5
  MATERIAL  "CM25"  M 2.402E-12  W 2.356E-08  TYPE "ISOTROPIC"  E 25  U 0.2  A 9.89999989542412E-06
  MATERIAL  "CM25"  DESIGNTYPE "CONCRETE"  FY 0.5  FC 0.025  FYS 0.5
  MATERIAL  "CM30"  M 2.402E-12  W 2.356E-08  TYPE "ISOTROPIC"  E 27.386  U 0.2  A 9.89999989542412E-06
  MATERIAL  "CM30"  DESIGNTYPE "CONCRETE"  FY 0.5  FC 0.03  FYS 0.5
  MATERIAL  "CM35"  M 2.402E-12  W 2.356E-08  TYPE "ISOTROPIC"  E 29.58  U 0.2  A 9.89999989542412E-06
  MATERIAL  "CM35"  DESIGNTYPE "CONCRETE"  FY 0.5  FC 0.035  FYS 0.5
  MATERIAL  "CM40"  M 2.402E-12  W 2.356E-08  TYPE "ISOTROPIC"  E 31.623  U 0.2  A 9.89999989542412E-06
  MATERIAL  "CM40"  DESIGNTYPE "CONCRETE"  FY 0.5  FC 0.04  FYS 0.5
  MATERIAL  "CM45"  M 2.402E-12  W 2.356E-08  TYPE "ISOTROPIC"  E 33.541  U 0.2  A 9.89999989542412E-06
  MATERIAL  "CM45"  DESIGNTYPE "CONCRETE"  FY 0.5  FC 0.045  FYS 0.5
  MATERIAL  "CM50"  M 2.402E-12  W 2.356E-08  TYPE "ISOTROPIC"  E 35.355  U 0.2  A 9.89999989542412E-06
  MATERIAL  "CM50"  DESIGNTYPE "CONCRETE"  FY 0.5  FC 0.05  FYS 0.5
  MATERIAL  "CM60"  M 2.402E-12  W 2.356E-08  TYPE "ISOTROPIC"  E 38.729  U 0.2  A 9.89999989542412E-06
  MATERIAL  "CM60"  DESIGNTYPE "CONCRETE"  FY 0.5  FC 0.06  FYS 0.5
