Custom dimension-tags used with i.e. flow drilling
Hi all,
We are starting the transition in production of using Flow Drilling for threading tubes instead of using rivet nuts.
Now I am looking for a way to automate a "Flow Drill Feature" and automated handling of the dimensioning on the drawing.
First idea was to use the Design Library but this is too much of a hastle when placing many holes as each hole has to be place separately instead of defining the locations of all the holes in one sketch like the Hole Wizard does.
I am looking for an identical workflow to the Hole Wizard which can place flow drill shaped holes.
If not possible a "flow drill favourite" would be an option to add to the hole wizard, just showing a simplified hole with thread.
But essential is when adding dimensions to the drawing I would like to have an automatic function which shows the text "FLOW DRILL M <DIM>"
Actually what the smart dimension tool does, recognising thread (M (for us metric people)), a hole (<MOD-DIAM>) or a linear dimension.
Anyone some advise on this matter? Would be very grateful! =)
RE: Custom dimension-tags used with i.e. flow drilling
Thanks so much for the quick respond!
Yes, that would be a possibility but it does limit you in placing the features in a linear or circular way.
I know I am looking for something which is pretty high-tec, usually I get stuff figured out myself, but I need a hand on this one though.
An other option would be making a VBA macro which can be run from the toolbar, but this brings a great amount of work with it which I am not looking for atm. I want to keep it as "clean" as possible.
Looking forward to hearing from you guys!
Jeff Mirisola, CSWP
Director of Engineering
M9 Defense
My Blog
Cheers,
Anna Wood
SW2011 SP5, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
Great stuff, thanks you guys!
