Steel Reinforced PE Piping Haunan
Hi All,
Has anyone any experience in the design of this product? I am particulalry interested in the techniques used for joining for pressure applications yet maintain the integrity of the corrosion resistance afforded by the PE.
http://www.huahan.com/english/technology_eng.htm
"Sharing knowledge is the way to immortality"
His Holiness the Dalai Lama.
http://waterhammer.hopout.com.au/
RE: Steel Reinforced PE Piping Haunan
Stephen Argles
Land & Marine
www.landandmarine.com
http://www
Large diameter, 'pressure' joints are going to be difficult. If you are looking at a smaller diameter, reinforced thermoplastic pipe (RTP) with a specialist jointing system may be a possibility.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
For this type of pipes I think its for gravity applications.
There is another pipe technology as worldwide unique PATENTED pipe as anti bacterial 3 layers pipes AB-3P , high impact resistant pipe, patented polymer compound and super high pressure twin conical screw extrusion process makes it an extra strong pipe. this plastic pipes compete steel and ductile iron on impact test, compression test, this plastic pipes can work with pressure 20 bars for water. Hygienic pipes for drinking water.
The below YOUTUBE for extreme test for it:
ht
manufactured by ME-PLAS Malaysia
http://meplas.com.my
Kandeel
