Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...On your site I feel quite confident that the contacts and feedback will make my life a little less hectic..."
Geography
saadati (Mechanical)
2 Jan 12 10:53
Protection pressure feed pumps in power plants, because there? Feed pump output pressure is low because the trip?
Helpful Member!  JJPellin (Mechanical)
2 Jan 12 11:08
Please ask someone to help you reword the question.  We cannot understand what you are asking.
Johnny Pellin
2 Jan 12 12:14
In power plant why  The main feed pump trip on low suction pressure?
Helpful Member!  steamdog (Chemical)
2 Jan 12 13:33
To prevent the pump to run dry - without any water in it.
Helpful Member!  bimr (Civil/Environmental)
2 Jan 12 14:42
Low pressure at the suction side of a pump can encounter the fluid to start boiling with
•reduced efficiency
•cavitation
•damage
of the pump as a result. Boiling starts when the pressure in the liquid is reduced to the vapor pressure of the fluid at the actual temperature.
http://www.engineeringtoolbox.com/npsh-net-positive-suction-head-d_634.html
Helpful Member!  Artisi (Mechanical)
3 Jan 12 6:42
The pump has been selected to run with correct suction pressure, any reduction of pressure can cause damage, therefore suction pressure is monitored and will trip if low.
or
suction pump run pressure correct to low trip for damage with
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
