Minimum spacing for G4 XLO QREC Quick Response, Extended Coverage
Happy New Year everyone!
I think I know the answer but being a slow holiday (yeah, I'm working) I thought I would ask the collective wisdom this forum supplies.
Minimum spacing for the Reliable Model G4 XLO QREC Quick Response, Extended Coverage Concealed Sprinkler
Cut sheet:
http://www.reliablesprinkler.com/pdfs/products/144%20G4XLO%20QREC%20Concealed%20ConcealerPlus.pdf
Minimum sprinkler spacing is 10.5 ft.
Consider the sketch http://img403.imageshack.us/img403/7851/g4xloqrec.jpg
I think I can space these sprinklers < 10'-6" apart if there is a soffit as shown.  Other than cold showering is there any other reason for the minimum spacing requirement?
This is a really large job for me and I don't need to be making silly mistakes.
Thanks.
RE: Minimum spacing for G4 XLO QREC Quick Response, Extended Coverage
It appears you are good to go.  Your ceiling construction satisfies 13-2010 8.8.3.4.2.
Neither NFPA 13 or the datasheet specify a minimum square footage for EC heads (like ESFR), so my interpretation is that the concern lies with cold-soldering, and not overwhelming the system due to excessive heads being opened.
8.8.3.4.2  Sprinklers shall be permitted to be placed less than 8 ft (2.4 m) on center where the following conditions are satisfied:
snip
(3) Baffles shall be not less than 8 in. (203 mm) wide and 6 in. (152 mm) high.
I am going to play safe.... I think what I will do is place them 10'-6" apart.
Most want to max out the spacing???
"Most want to max out the spacing???"
For most of it I'm hitting 18'x18' but a messier than usual ceiling layout, with multiple pockets and light fixtures centered in those pockets, that keep away head placement.
