Difference in allowable stresses in ASME Secton II part D & B31.3
I went through some of the relevant threads with respect to above and found useful info. from seniors on this, but i would like to know the reason for this difference in allowable stress for material listed in both Secton II Part D & B31.3, for example Material SA 516 Gr. B can be used for Pressue Vessel as well as for piping but at all times if i am designing piping i have to use values from tables available in B31.3. Why i can't use values from Part D.
From some info. available at net, i found that it has something to do with safety factor. Would highly appreciate respone in little bit more detail if this is the case.
Meck 91
RE: Difference in allowable stresses in ASME Secton II part D & B31.3
SA-516 does not have letter grade numbers and is a plate spec.
Please correct, and I will try to assist as much as I can.
Sorry, its a typo. Let's cnsider any grade of SA-516. All can be used in ASME Section VIII Div. 1 & B31.3.
Thanks.
Each Standards Committee is charged with maintaining their code book. This means use of material, safety factors, welding requirements, fabrication requirements, service loads, and yes, allowable stresses.
I don't think I could have answered it better, metengr.
The safety factors are different. 3:1 on UTS per B31.3 & 3.5:1 on UTS per ASME VIII, Div.1.
