Use an excel parameter list across an entire project
I would like to use an excel parameter list across an entire project. I'm trying a top down modelling approach. I've linked the excel file to the first assembly I've created which I'm using as a skeleton which has the outlines of all the major parameterised features. From then onwards I want to create new parts and then project lines from the skeleton part to create individual parts. Then if I change the skeleton everything should move with it.
The problem I'm having is that for each new part I need to manually go in and select the excel file containing the parameters. Is there a way to do it automatically for each new part and assembly?
Many thanks
George
RE: Use an excel parameter list across an entire project
There is not an out of the box way to automatically do this.  You could do a couple different things though to make life a little easier, but it involves up front work.  You could use an external iLogic rule or templated part/assembly with an ilogic rule in it to point to a spreadsheet and create the link.
That's the way I'd do it - I'd create a hardpoint (that's what we call them) part that refers to the excel file, and then link my part geometry back to the hardpoint part.
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
Thanks for the replies,
Cheers
George
