Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Congratulations on a brilliant idea and a great site..."
Geography
Hclrag123 (Mechanical)
30 Dec 11 20:45
I need an I Beam for my fixture design of a material having 80-100 KSi Yield and Tensile. Something similar to X80.
The Size of the Beam is W44.
Can anyone suggest a suitable material Beam available in the Market?
Can we build one by welding the X80 Plates? Will the Section modulus be the same as the original I Beam?
CoryPad (Materials)
31 Dec 11 1:54
A suitable standard would be ASTM A1011.  A suitable material would be SS Grade 80 or UHSS Grade 90.  A suitable product would be Weldox 700 from SSAB.  You can build the beam by welding plates.  The section modulus should be similar.
metengr (Materials)
31 Dec 11 10:41
If you go with the Weldox 700 structural steel make sure that you visit their web site and download their Joining technical brochure. It is a good technical reference document for welding. As with any HSLA steel you need to understand specific welding requirements to avoid altering bulk mechanical properties.
Also,  I would ensure some type of surface and volumetric nondestructive testing be performed of the fabrication welds especially if you are going to use partial or full penetration welds for construction of this I-beam.
31 Dec 11 20:23
Thanks for the info guys.
I am trying to open the website SSAB.com but the website is not opening. Any other suggestions?
What is the maximum Ksi for a W44 ready made I-Beam that i can expect in the USA Market?
CoryPad (Materials)
1 Jan 12 10:11
You can expect properties to meet ASTM A 992, which means 50 ksi yield and 65 ksi ultimate.
Close Box
Join Eng-Tips® Today!
Join Us             Close
