Pro \II simulation book or paper for beginer
Dear Sir/Madam
Could you please kindly suggest any Pro \II simulation book or paper for beginner to do the process design?
For example, process engineers have to do property calculation, such latent heat calculation for the mixture, the distillation column relief valve outlet composition, column bottom outlet composition at relief condition, Quench water rate for the reboiler at relief condition, etc.
Your help is much appreciates, and thank you very much for your time.
