proper material
proper material
I need a bearing/wiper material to use on a slow motion sliding polished chrome rod think linear motion. short throw Like three inches. I would like the material to be castable at low temps and slide free of friction within reason. Fairly stiff as it would have a max 50 pound load on each bearing.
Any suggestions?
Any suggestions?
RE: proper material
I am presuming you are using the word castable in an appropriate manner and you have correctly rejected other possibilities for method of manufacture.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
RE: proper material
RE: proper material
Pat
for site rules
RE: proper material
RE: proper material
Pat
for site rules
RE: proper material
I could cast directly into a clay mould. I know! Which plastic right?
I don't know but I think it's a smooth on product.
I'm going to think about doing it like that. I have been looking for a project for that plastic for a while now.
Thanks for your help. It really was helpful and actually learned a couple new terms to research.
RE: proper material
If you support the guide rods in ball bearings and drive them with a chain or belt so that they are always slowly rotating, the stick/slip problem should be greatly reduced, regardless of bushing material.
... at the expense of some added complexity, I admit.
If you have access to a lathe, you can buy Delrin rounds and machine your own bushings to whatever spec you need. PU is indeed castable, but I think you will be disappointed at the amount of graphite, or oil, or grease, that's required to keep it slippery.
Mike Halloran
Pembroke Pines, FL, USA
RE: proper material
Oak also makes a decent bearing material (relative to no bearing at all) and was used for centuries as such. Lignum Vitae is better, but a little more difficult to come across at your local lumber yard. The guy behind the counter will most likely have no idea what you're talking about.
RE: proper material
Just sayin......cost is relavant and if your dinkin in the garage with other expensive tools that crap can add up. Sides, I kinda get a kick out of poorgoying parts and tools which is a good thing because I have had less than stellar results on occasion.
RE: proper material
