2012 Sheet Metal and Service Pack
I have a sheet metal part saved on Windows 7, SW2012 SP1 64 bit. When I try to open it on Windows 7, SW2012 SP0 32bit, I get an error and the file won't read in. This only happens with sheet metal parts. Has anybody had this exact same problem between both service packs and 64/32 bit? It will of course open on the 64 bit machine.
The VAR says this shouldn't happen.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
RE: 2012 Sheet Metal and Service Pack
I was also under the impression that a SW file should not be affected by SPs, 32/64 bit editions, nor even Windows version.
Does this happen with all parts, or just this SM part.
Can you post it or similar for testing on my XP x32 system?
