Superelements in ANSYS - problem with coincident nodes
Hello, I would like to use a superelement in my model, but in the boundary, where have to be defined coupled pairs of nodes, there is defined a contact between two surfaces with different numbers of elements -> so I can´t define coupled pairs of nodes (there must be defined a contact becaulse of the connection between wto areas with different meshes). Is there any way how to solve such a problem?
RE: Superelements in ANSYS - problem with coincident nodes
