UG NX Moldwizard Component Naming
I am a mold designer using Moldwizard with NX 7. I was wondering if anyone can tell me how to change it so that when you add a component it will come in as <name>_1 and then increment to <name>_2 instead of how it currently comes in as <name> then <name>_0
example
current way
input slide assembly from slide library comes in as <project><slide assembly>
now bring in a second assembly and it comes in as
<project><slide assembly>_0
i would like to change a customer default or something so that it will come in as
input slide assembly from slide library comes in as <project><slide assembly>_1
<project><slide assembly>_2
Also we do not use teamcenter at my work so that might be the reason for my problem i am just not sure as i dont have any expirience with teamcenter.
Thank for any help
JSModeldie
example
current way
Thank for any help
JSModeldie
