Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...It is good to know that there are groups such as this willing to share knowledge in this money driven economy..."
Geography
lessfull (Aeronautics)
28 Dec 11 15:58
Hi everyone
I have a tolerance that states "// 0.025/ 100 in to datum A"  in milimeters
I'm interpreting that means parallelism within 0.025 mm over a 100 mm diameter area relative to datum A.
Is it correct?
Tanks
Belanger (Automotive)
28 Dec 11 17:39
Almost correct, except that I'm not sure about the "diameter" thing. To say that, there would be a diameter symbol Ø before the 100; without it we would just assume linear length of 100 (although that too can be confusing because I would usually show another dimension, such as 100 X 12).
I also wonder what the "in" means after the 100 -- did you mean mm?  It would be strange to mix a millimeter tolerance with an inch dimension on the local segment.
John-Paul Belanger
Geometric Learning Systems
29 Dec 11 14:06
Well, i was trying to put in words what appears in the drawing, the "in", i meant it to relate the values to the datum A, the "in" doesn't appear in the drawing. Is only milimeters the tolerance.
Trying another time:
"   //0.025/ 100   "
it's what appears before the reference to datum A. The diameter was an interpretation i made but my initial tought about it was a linear section of 100 mm, but then only appears as i wrote above without anything after the "100".
Tanks for you attention
Close Box
Join Eng-Tips® Today!
Join Us             Close
