Pipe material for welded carbon steel
Hi
what is the better option for welded C.S. pipe (SAW or EFW) for 26" and above?
Is it better to apply it starting from 26" or from 16"? At the moment I'm using API 5L Gr.B PSL2 SAW from 26", but several companies use different specifications.
RE: Pipe material for welded carbon steel
The only way to confirm that the welding is going well at the pipe mill is to test the weld seam as soon as possible. I have met several 3-rd Party Inspectors that have found out-of-calibration UT or Eddy-Current [ET] equipment in use at pipe mills. Want to guess how many flawed welds were shipped based on this "testing"?
It's not the process, it is the care and professionalism of the pipe mill.
