How to "vacuum form" an existing part to make a form-fit accessory
3
I saw this controller add-on online this weekend while doing my normal web browsing (post was about bad PR from the company, but that's beside the point), and I was wondering about the technique used to "vacuum form" the part.  It doesn't appear that they used a traditional vacuum form, but rather had a CAD model (or 3D scan) of a controller and was able to make the neatly contoured device with that.  If I had a model or 3D scan of a part with complex geometry like the XBOX controller, how would I go about creating a contoured "indention" in another part/assembly in Solidworks so that it would have that nice glove-like fit?
Here's the link to the product I'm talking about:
http://www.avengercontroller.com/picture.php
Any tutorials or even the proper name for this technique would be appreciated.
Thanks.
RE: How to "vacuum form" an existing part to make a form-fit accessory
Look in Help under Cavity Tool, or Tutorials for Molds.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
I agree with MM.
If you have a SW model. If not, the 3D scan is your option.
You could also do a surface offset of zero, then thicken to make the part.
Various ways to do things in SW. winky smile
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
The Indent tool could also work for you.
Cavity tool will only do part of the work. It will create a cavity that completely surrounds the object which is not how thermoforming works. Typically a thermoformed package does not wrap around the part.
Basically you would have to create the top surface of the controller, use the dome feature to build a bubble around the buttons and a sweep to build a bubble around the arms. From the top surface edges extrude down to the backing. Then add necessary draft as a last step.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
Thanks guys, good answers!
The cavity tool will work for the things I want to do with it.  I was aware of it before, but it was always presented as if it was only useful if you were actually making a full injection mold rather than just trying to get a negative of the part.
SW creates geometry. It doesn't know what the end use of the geometry is per se.
The cavity tool doesn't require making a full cavity either.
You could also use the dimple tool in sheet metal although I've never used it on something that complex.
TOP
CSWP, BSSE
If you have multiple bodies in a part, i.e. the filled in exterior of your accessory and the part you want it to fit aroud, you can use the combine feature and select subtract.  It is under Insert->Features->Combine...
Doug
