Anodes: Potential Attenuation
Hi Engineers!
I have designed a cathodic protection system for pipelines using bracelet anodes (as per DNV-RP-F103) and spaced them such that current requirement is met for the spacing length suggested (max 300m). Now I realize I need to consider potential attenuation at half length which I'm unable to calculate. I understand I need to consider metallic linear resistance along the pipeline and transverse pipe-to-seawater insulation resistance. My pipeline is just FBE coated with 0.45mm. Could anybody suggest how to estimate the insulation resistance (ohm-m2)? or a ball point figure conservatively?
Thanks in Advance.
Cheers,
Uday
Pipeline Engineer
RE: Anodes: Potential Attenuation
See the answer under offshore structure engineering.  Please don't multipost.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
