NX8 Manufacturing - engage retract feed default settings
I have a problem. Since NX8 the default engage and retract feed settings has changed from 100%Cut to Rapid (Feed rates-Feed rates-More). This is very bad default setting, because the cutter can be inside material at the time, i broke several mills until i found out this has changed since NX7.5...
Is there any way to change this back to 100%Cut or other custom value.
I can do it manualy every time, but it takes time...
Thank you.
RE: NX8 Manufacturing - engage retract feed default settings
Change the Template file.  All of the operations use a template.  Open the template file and change the feeds to the desired values.
For example when you create an operation and select a type  such a mill_planar you are using a template part that is named mill_planar  if you make any changes to th template then this will become the default setting.  If you understand templates then great, if not I would recommend reading the docs on this very important topic.  Templates can save you a great deal of time and as we all know time IS money.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6.0.5.3
Thank you for your explanation joyceo.
It turned out i made a mistake, the default setting is correct. The thing that changed since NX7.5 is when I push "Set machining data" wich I imported from the previous version, engage and retract are set to Rapid.
I found out that I can solve the problem when Editing all machining data libraries Engage and Retract do 100. I think this is a bug since default values are 0, so nothing should change if I set it automaticly, right??
The question of what a zero feed really means has caused us some confusion over the years, so in NX8 we eliminated them. Now you explicitly say if you want rapid, %Cut, or an exact value, and WYSIWYG.
Your engage value of 0 in the machining database should have coverted to 100 %Cut. This is a known issue.
Mark Rief
Product Manager
Siemens PLM
