Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I love the structure of the site. You start at the top, and drill down to what you want. Maybe I've been using Unix too long... :-) "
Geography
cosmos2c (Automotive)
27 Dec 11 0:51
Can anyone assist me please, I need to couple up to rotating shaft using a non-abrasive clutch.
The shaft is able spin in both directions, need a dynamic solution not a static one.
The clutching power must be of very high torque levels, e.g.;  a prop-shaft on  a car, the mechanism needs also to be inline.
Cosmos2c
patprimmer (Publican)
27 Dec 11 4:20
Will a dog clutch work
How much control will be needed re selecting when to engage it, ie can someone pull a lever or whatever or does it need to be automatic.
Does the shaft need to idle free without drag for a certain time or is it gust to change direction.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
27 Dec 11 4:58
Thanks Pat,
I suppose it will be easier to state that I have a new shaft mechanism to brake the rotating shaft. I do not want the new mechanism running all the time as the shaft is spinning,I wish to engage the braking mechanism at will so it needs to engage immediately and accept the forces involed and cope with them.  Oh and it must disengage at will when required.  I think some sort of ball clutch aor a ca would m lock mechanism would be the sort of thing but do not know enough about such devices and their physical power ratings etc.
27 Dec 11 6:59
Look at sprag clutches or lock up converters in modern automatic transmissions. A double clutch set up might be possible or a modified sprag with double action maybe?
Pat
for site rules
27 Dec 11 7:26
Pat thanks you very much, I think the Sprag Clutch is probably the best solution as it wii be a cost effective and I can use 2 of them and that will take care of the direction os spin too.  I did look at magnetic clutches but were too expensive and only worked to low revs to engage.
desertfox (Mechanical)
2 Jan 12 13:33
Hi cosmos2c
Have a look at these sprag clutches-
http://www.renold.com/Products/SpragClutchFreewheels/Sprag-Clutch.asp
Close Box
Join Eng-Tips® Today!
Join Us             Close
