Removal of dissolved NaCl from 10-16% PtN solution?
I am presently trieng to figure out the removal of NaCl from PtN solution. No hydrocarbons as carriers if
you're planning liquid-liquid extraction, PtN is a good oxidising agent and u'll be cooking up an explosion.
I wanted to take advantage of the eutectic mixture, by adding more NaCl, drop the temp for NaCl to re-crystalise and then filter. But my bosses will rule against it as if it fails, we got a lot of platinum that has been messed up.
Any other separation technique to consider? Please help. I need to get rid of NaCl without compromising PtN solution.
RE: Removal of dissolved NaCl from 10-16% PtN solution?
It sounds like something similar.
Additional research on the adams catalyst might lead you to your solution.
FYI PtN is really Pt(NO3)4
StoneCold
