SE will not reinstall
I have a licensed 64 bit version about 1.5 years old and it was working fine on Win7.  I have not updated to the latest version so I can not call SE tech support. The program has not been used for about half a year and when trying to use it today I got a message saying it was not registered or needed reinstall.  I have not changed any hardware.
I ran the repair from the install disk and it said all was fine.
Still I got the same error message.
I used the SE uninstall command, rebooted and then tried to install SE from scratch but now I am getting a message that an existing version of SE is installed.
How can I get rid of the hidden leftover stuff?
Any suggestions what caused my problems?
Thanks in Advance.
Bertho
RE: SE will not reinstall
Download ccleaner and run the program.
Solid Edge ST4 Premium
MACBook pro 8GB RAM
Thanks RAMviking for a fast reply.
Unfortunately after running both Norton360 registry cleaner and ccleaner the problem is still the same.
Any other suggestions?
Is viking relating to your origin?
Bertho working at Vinland.com
Update:
Eventually I found on the install DVD: d:\solid edge\spt\tools\SECleanupAll.exe
It fixed the problem.
Bertho
Hi Bertho, your site is very interesting
Yes, I´m living in Norway.
Working with offshore solutions, www.bandakgroup.com
Nice to hear that you have solved the proplem smile
MACBook pro 8GB RAM
