Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site is a great idea. I should have joined your site years ago. Better late than never..."
Geography
Cyriluitnederland (Automotive)
23 Dec 11 11:00
I can't get my head around how torque is split unequally using a planetary centre diff(e.g. 30-70% f/r ratio). The fundamental laws of gearing say that for a given gear ratio, the increase in torque is inversely related to the rotational speed. However for 70% of torque to go to the rear axle it must rotate faster than the front axle (as defined by tyre characteristics).
What causes the torque to be split unequally? And how is this linked with the rotational speeds?
I have read design of machinery and Mechanisms and Dynamics of mechanics but still don't understand it.
Thanks a lot!
MikeHalloran (Mechanical)
23 Dec 11 12:27
First, think of a bevel gear differential as a special case of the planetary, where the torque split happens to be 50/50.
Now, visualize the bevel gear diff, and unwrap it in your mind, retaining but distorting its topology so that the bevel gears become spur gears.  So, it's morphed into a planetary.
Having done that, you can maybe appreciate that if you juggle the gear ratios, the planetary diff can have a split other than 50/50.
Mike Halloran
Pembroke Pines, FL, USA
23 Dec 11 13:12
Something along these lines?
First for a 50-50% as found in bevel diff
                          | Ring
                     _    =    _
Planet 1             |    |    |Planet2
                     =---------= Spider
sun1 going to front  |         |   Sun2 going to rear axle
And now with sun2 larger, causing larger torque output to the rear?
                          | Ring
                     _    =    _
                     =---------= Spider
WolfHR (Mechanical)
23 Dec 11 13:38
ISTR that there are asymetric bevel diffs as well, with one of driven gears being smaller... So torque gets split according to 50-50 power distribution and the speed difference is sorted out with different final drive ratios.
patprimmer (Publican)
23 Dec 11 16:32
If you correct asymmetrical torque split with different FD ratio, surely that negates the torque split as well.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
izzmus (Automotive)
23 Dec 11 21:38
Torque is independent of motion, and a differential under normal circumstances will see no internal relative motion.
Maybe that is where you're getting tripped up?
Under normal circumstances, the gears aren't moving, so they become little more than odd-looking levers.
GregLocock (Automotive)
23 Dec 11 22:39
here's an explanation
http://www.bib-nakladnistvo.hr/integralediff.pdf
Cheers
Greg Locock
New here? Try reading these, they might help FAQ731-376: Eng-Tips.com Forum Policies  http://eng-tips.com/market.cfm?
Close Box
Join Eng-Tips® Today!
Join Us             Close
