FRFs comparison
FRFs comparison
Hi all,
I am comparing two FRFs acquired on a cantilever with two different holding systems. I am comparing in receptance format so that I can find out the compliance (or stiffness) of holding system.
System A shows lower amplitude than System B on receptance plot, indicating that System A holding stiffness is better than that of System B.
But I also noticed that the cantilever natural frequency is lower while holding with System A. How can this be explained ? I am expecting an increase in natural frequency as well (due to increased stiffness). What does the change in natural frequency indicate in terms of holding system effectiveness ?
I am attaching the FRF picture here.
Thank you and Merry Christmas !!
Geoff
Geoff
RE: FRFs comparison
Cheers
Greg Locock
RE: FRFs comparison
Thank you for the response. Actually this is the data converted to receptance from inertance. So I see a big spike at 0 Hz (could be due to DC component) and hence while displaying I shifted the graph a bit !! Sorry for this. Please find attached full graph.
I am not sure about the second mode. Actually these are two FRFs acquired on a cantilever with two different holding systems. I am trying to evaluate which one is holding better. So I did a quick tap test on both configurations.
From displacement amplitude, I can see the system with blue color FRF is good. But I am not understanding why frequency shifted to left. Generally better the stiffness of holding, higher should be frequency of object that is held. Is this true ?
Thank you very much.
Geoff
RE: FRFs comparison
If that is driving point data then you've definitely got some problems with test technique, phase should be in a 180 degree band.
Cheers
Greg Locock
RE: FRFs comparison
Thank you so much for the reply. Can you elaborate a bit about that 'special case' ? I see it can happen if the fixity is so strong that it acts like mass addition, then wn = (k/m)^0.5 and this may lead to reduction in natural frequency. Could there be any other possibility ?
Reg phase, I have that doubt as well ! But I didn't want to mix up the things. Actually the inertance plot shows phase of -180 to +180 deg. Please see attached figure. But when I convert to receptance, this is happening. I am not sure why. I am puzzled at it as well. Any comments ?
Thanks a lot. Merry Christmas.
Geoff
RE: FRFs comparison
Can you do driving point measurements rather than these?
Cheers
Greg Locock
RE: FRFs comparison
Thank you for the response. I also believe that the software is making some mistake in phase calculation while converting from inertance to receptance.
Unfortunately this is the only measurement I have for this structure. I just did a quick check to compare effectiveness of holding. However I will now do a drive point measurement as well.
Can you comment on that special case of fixity which you were referring to ? Does my assumption of strong fixing adds mass and hence reduction in natural frequency correct ?
Thank you.
Geoff
RE: FRFs comparison
The reason is that as you've suggested, coupling an infinite mass to the beam has a larger effect than the constraints. The apparent paradox is resolved when you bear in mind that the free free beam's first mode is at 0 Hz.
I suggest you do a proper modal on the structure to get an idea of what is going on, looking at single FRFs is too confusing.
Cheers
Greg Locock
RE: FRFs comparison
Geoff
