MCC Bus Rating Selection
We have load calculation tables with detailed listing of all motors and other loads with their respective efficiencies, power factors and LOAD FACTORS.
We use this to size the upstream power transformer which is supplying the main switchgear. However, the swithcgear is supplying power to couple of MCCs. The vendor sized the MCC based on the load calculations we prepared.
However, I believe the MCC bus rating should be sized according to 100% load factor (same philosophy with feeder cables). Is my design approach correct...your comments are highly appreciated.
RE: MCC Bus Rating Selection
